New Appliance Service Manual added: Jenn-Air & KitchenAid Built-In Refrigerators Control Board # W10219462 Replacement Service Pointer
View File
Models:
See attached pointer
Serial Numbers
All Serial Numbers beginning with Q or S
Q = LaVergne Manufacturing; S = Fort Smith Manufacturing
Possible Concern:
Control board W10219462 is no longer available as a stand-alone component. The control board is used in KitchenAid and Jenn-Air Built In Refrigerator Units -- SXS Dispenser, SXS Non-Dispenser, 36” Bottom Mount, and 42”French Door Bottom Mount.
Potential Cause:
Any problem necessitating replacement of Control Board W10219462
Correction:
Reference tables on the following page to order and install service kit for the applicable model.
Service kit contains:
• Control Board Assembly (Including Wiring Harness)
• Multiple Control Boards
• Mounting Bracket, and
• Instruction Sheet
Note: Functions performed by the original control board are now performed by multiple control boards.
Pub # W10802724
Release Date: June, 2015
