Looking for a manual or tech info on this Kenmore fridge made by Whirlpool. Thanks in advance.
Closest I can get on Kenmore stuff is by crossing the model number over to an OEM equivalent using a key component, like a control board. Similar to Canadian models. I've gone ahead and done that for you this time:  http://appliantology.org/files/file/2394-whirlpool-gs6shaxlq02-refrigerator-tech-sheet/
If you do this yourself in the future, you'll get manuals quicker.
Thanks Samurai. How were you able to cross it over to that particular model number without seeing the unit first to get a key component part number off it in order to get an OEM equivalent? That's what I'm trying to do, get the tech info to pre diagnose the problem before the call in which case I won't have any part numbers to cross reference. I must be missing something here... Thanks again for your help with this issue.
Look up the Kenmore model number at the Sears site and find a key component from there. Get that component part number and plug it into the search at AppliancePartsPros. Scroll down and it'll show a list of compatible models. Select an OEM model number and you're home free!
OK, Only problem is that you can't get info for all Canadian Kenmore's on the sears site, but have got some. When you enter the part # at APP, you get a vast number of compatible machines. Do you have a better chance picking one near the top of the list? Thanks Samurai.
It really seems to vary-- I don't think the list is sorted in any order that's helpful to our purposes.
The only other thing you could try to to find an online Canadian parts house and cross reference the part number on that site to pull up a compatible Canadian model number.
