    • 15 March 2025 02:00 PM Until 03:00 PM
      5
      When: Saturday, March 15 @10:00 AM Eastern Time.
Guest Joe Del
I need a Kenmore Frigidaire Range 790.90219013 service manual, wiring schematic or tech sheet.
Edited by Joe Del
Tech sheet link per admin approval. Available only after approval.
http://appliantology.org/files/file/2487-frigidairekenmore-30-elec-range-tech-sheet-316441472/
Be sure to study up on how to search for manuals on the site. Admin provided good info on how to search.
I believe this is the service manual for that range.
http://appliantology.org/index.php?app=core&module=search&do=search&fromMainBar=1
Guest Joe Del
Wes, the links still do not work. Am I missing something or is your link still wrong? See the screenshot from this morning. Thanks in advance for your help.post-101879-0-04735600-1444137624_thumb.
Which one? All 3?
The first link for the tech sheet is still waiting to be approved.
The second link is bad.
The third link should work for the manual.
Guest Joe Del
Can you confirm the third link? This link is what takes me to the screenshot "SORRY"  http://appliantology...ng-ranges-2005/ again thanks for your help. I understand if your busy, we all have to go to work, so I can check later after I get a couple service calls completed.
When I click on the link it takes me to the download. No errors.
I see you actually downloaded the manual yesterday evening.
You can try and search the number to see if that will work.
5995438461
I don't know why you would get the error. The link works for me.
Guest Joe Del
BTW, I am looking at the tech sheet that Samurai posted. On paper it looks like this could also be it, but I need to be sure. This range belongs to a Rent-A-Center and their internal store handyman basically unwired the entire harness in an attempt to repair the range. I am sure it will be an easy fix - but not without the correct schematic for verification. Again Thanks in advance, Joe
 Master Appliantologist's Sapporo Den (Tech-only Forums)   Appliance Service Manual Requests
New Appliance Service Manual added: Kenmore Frigidaire 790.94034702 Range Tech Sheet
Started by Samurai Appliance Repair Man24 Sep 2015   icon_tag.png KenmoreFrigidairerange
It is not downloading the manual, it says it is and then the error. I will probably need to wait for admin approval?
Not sure what is going on with the link.
Just to be clear the first link was for the TECH SHEET. Still waiting on admin approval.
Disregard the 2nd link altogether. My mistake.
Third link is for the SERVICE MANUAL number 5995438461
If you have downloading issues be sure to contact the ADMIN. They will have to work out those issues.
Guest Joe Del
Thanks for your help, the Samurai just approved the link. Joe
Guest Joe Del
Wes, I wanted to thank you for your time and update you. I used the schematic from this site and was able to properly wire the harness and it now functions perfectly. I found out from a different employee there today that the maintenance man had replaced the control board (which did have obvious burned resistors) but he had disconnected all the wires on the back of the range! Now he could not get the wiring correct and the range control would not light or display or take any user input. It was believed he sabotaged the job so no one else could repair it.... especially if he couldn't ! Joe
No problem. Glad to help out.
Thanks for the update. Good job!
