In need of Kenmore Dishwasher 665.16534201 Service Manual
  • Replies 4
  • weswayne
  • an0m4ly
  • Budget Appliance Repair
Thank you for the link! The only issue I am having with that tech sheet is the diagnostic mode is not correct for this dishwasher.
I have run into the same problem. Even with my own Whirlpool dishwasher.
Tech sheet has a set of keys to press and nothing. Tried all kind of ways.
Gave up and just had to test as much as I could from the control board.
I don't know which actual service manual is relevant to your dishwasher.
Do you have the dishwasher serial number?
Maybe we can find out what year it was made and find a comparable Whirlpool manual.
Edited by weswayne
The techsheet WesWayne linked to should be the correct info your your dishwasher.  The parts list shows techsheet part# 8537797 for your dishwasher.
I haven't came across any of this style of Whirlpool dishwasher where either Hi-temp Scrub or Sani-Rinse with Air Dry key didn't put these into diagnostic mode unless the keypad is bad.
Did you try both combinations?  Hi-temp Scrub / Air-Dry / Hi-temp Scrub / Air-Dry
                                      And       Sani-Rinse / Air-Dry / Sani-Rinse / Air-Dry
One of these two combinations should put you into diagnostic from stand-by mode or into rapid advance mode if running.
