I'm having a problem with my LG WM2016CW front load washer.  I am receiving the LE error code.  I have replaced the sensor (apparently the most likely cause of the LE code) and motor harness and still am having issues.  The washer goes through part of a cycle and drum will spin before the error hits.  After I replaced the motor harness, I ran an empty load and it made it all the way through.  Tried with a small load and it made it through to the rinse cycle before the LE error appeared.  Any suggestions would be appreciated
Was the sensor verified to be bad? Did you test it?
I have heard that some people have installed them incorrectly. There are 3 tabs that  click onto the stator. It can be installed incorrectly on only two of the tabs.
I'd double check that and all wire connections.  If you don't find anything you'll need a multimeter to do some tests on the sensor.
Best of luck!
If the work you've already done checks out (installed correctly, etc) the next stop would be the control board.
Part number: AP5078533
<<<The washer goes through part of a cycle and rum will spin before the error hits>>>
<<<I ran an empty load and it made it all the way through>>>
<<<Tried with a small load and it made it through to the rinse cycle before the LE error appeared>>>
Verify correct type of detergent is used ("HE" type)
Verify correct dosage is being used...
HE: (2) Tablespoons Per Load
HE 2X (double concentrated detergent): (1) Tablespoon Per Load
HE 3X: (triple concentrated): (1) Teaspoon Per Load
Incorrect type or amount of detergent will trigger an "LE" error---at the *rinse* portion of the cycle.
Thanks for the feedback.
* I did not confirm that the sensor was bad.  It appeared that this was the number one culprit so I just replaced it - very small investment.
* I've always been stingy with the HE detergent, so that isn't an issue either.
* I rec'd the new control board and installed it.  I've successfully run one quick cycle and I'm half way through a full cycle with no LE error code - fingers crossed that this solves my issue.
