LG LDS4821ST motor sound continously running, no error codes displayed
Fireguy94304
LDS4821ST Dishwasher has a motor constantly running with no error codes displayed. The problem started after I tried to run a load of dishes before work and came home to the dishwasher sounding like it was still running. I had to disconnect power to get the dishwasher to turn off. If I plug it back in the motor begins to run again. What could be the cause? Bad controller? Bad PCB Assembly?
  • Replies 5
  • Fireguy94304
    4
  • john63
Serial Number will likely help explain the cause....
Fireguy94304
The dishwasher is a LG Model #LDS4821ST, S/N 811KWTA00009
Stuck in DRAIN MODE.
Usually caused by oils/fatty deposits from years of washing (contamination) or minerals in the water supply (clay/calcium etc)
Replace the GUIDE ASSY (Part number: 4975DD1001A
Part number: 4975DD1001A)
Located on left side of dishwasher (must be pulled from cabinet/counter for access)
Fireguy94304
Thank you John63! I will replace the part and let you know. Gotta be cheaper than a new dishwasher, even though the wife will say I am just cheap S.O.B.
  • 3 weeks later...
Fireguy94304
john63, that worked replaced the guide assembly and dishwasher working now. Thanks again
