I have replaced the following parts:  thermal cut off fuse kit, high limit thermostat and operating thermostat.  Heating element tested good, still no heat.  What to do next?  Everything else seems fine,
Posted (edited)
Since we know everything cannot be fine,  we have to know what else you checked and tested.
 here's a few questions to start with :
Did you check the breaker? test for 240v at the outlet?  Check for 240v at the dryer block? At the element?
Have you checked for heat using different settings?
btw,  you said the element tested good... how did you test it?
Edited by DurhamAppliance
Yes, checked the breaker, and for 240v outlet and element, all good there.  Brother in law has a multi meter:-)  Had the element checked at sears.  Tried in all settings, just nothing.  Dryer block?  Not sure what that is.  When I installed rhe thermal cut off fuse kit, it worked for a minute.  Put it all back together,  and it had stopped heating again.
Sipping a Yuengling now, kinda disgusted!
Ensure you have good air flow. Check all vents. Internal and external.
Come on!  You can do it... appliance repair takes patience... sounds like you are moving in the right direction... ie eliminating prime suspects.... that's progress!.... but not too many Yuenglings while working on a dryer!
MD Home Services
No heating problem? Check the timer. Someone give her a tech sheet or use the one in the dryer.
Posted (edited)
check your fuses again... bad air flow may have caused another blown fuse.... remove venting from dryer while testing to save money from blowing fuses for right now.
Also,  use the multimeter to find which leg isn't sending 120vac... then follow it back to find the problem
But of course!  Had too many beers already this week!  Yes, airflow is perfect, took all that apart as well, checking for clumps of dog hair, lol.  Truly stumped.  Hence the beer.  Thought stimulator and bravery all in one glass...
Posted (edited)
lol.
it may be the timer but want to rule everything else out do to cost/value consideration
Yeah, was thinking that too.  It does actually run through a cycle and shut off, though.  Would a thermal fuse be a possibility?  The ppl at Sears said that it was responsible only  for turning the drum, but the part description says something else, related to overheating if I remember right.  The thing is turning, and there is air flow, so.... ?
Put the timer on 60 minutes unplug dryer and look at the back of timer and you will see a Red wire terminal ( A ) and a Black wire   terminal ( C )   and check for continuity there if you don’t have any  Bad timer.
Unplug those wires to check for continuity.
MD Home Services
Do you have a tech sheet at the dryer? Timer is the last resort but they do go bad. I've replaced timer after everything else checked good. Of course, that's after checking timer and didn't ohm out.
Yeah, that would be the piece of paper tucked up inside where all the knobs are?  Yup, got that. will ask the brother in law to check that out with his fancy tool when I get out of the bar in about half an hour :-).   What should the reading be?
Awesomeness!  Will check for continuity there.  Thanks guys!
Thank you for that!  Got busy cleaning the pool (I'm in FL)  will get back at it tomorrow after work!
After seeing the part number for the timer I will bet it is that, that timer is shitty and always fail
You got that right brother:rolleyes:
just watch out for gators..... uh... and...  pythons!
Heh, not near the Everglades, else I'd have a shit ton of gator and snakeskin shoosies!  Will be home 6-ish to check that timer!
What did you find? gator gotYou?
Heh, no I've just got a hundred things going on right now.  Thanks for the advice, timer it was!  installed it last night in no time, took longer to put the back panel on, lol!  How many women you know could live that long without a dryer?!  Now, got a problem with the garage door opener...  any takers?  For real. :-(
Thanks for getting back to us.
