Hello I have a maytag centennial washer mvwc7esww0 and it wont fill with hot or cold water.  Only thing I can get it to do is spin, the water valves are good and lid switch is good.  I put a new (open Package) ATC switch in and didn't fix.  So I'm guessing either the new open package atc switch is bad or maybe a timer.  How can I test the atc switch or timer.  Any help would b apprecia ed .  Thanks
  • Replies 8
  • joey128
    5
  • sh2sh2
  • Captain Dunsel
What's the part number of what u replaced, did it gave a clear hose running to it, if your model number is correct the part u need to replace is the fabric softener switch
the atc switch number is w10248240 and the fabric softner switch has continuity on softner added and no continuity when no softner added so isn't it good
yes it had clear hose, its the temp/pressure switch
Ok, I was thinking of a older version
After you change out the ATC switch did you blow down the pressure switch tube that goes into the tub to clear any obstructions that maybe down there.Part number: WP353244
yes its all clear, do yall think I got a bad atc switch, i bought an open package one so i think someone might have returned there bad one.
This old post may help.This is a different model number but has the same ATC switch.
Yeah I'm getting power to atc switch but not out to water valves, guess I'm going to order a new atc switch and see if i got a bad one
