This machine needs a belt. All of the sites I have visited call for a WH01X10302  belt. Well, it won't fit. By "won't fit" I mean to say it won't even go around the drive pulley by itself, much less the drive pulley and the motor. The pulley is correct. ( I bought a replacement).  Old belt is ruined so I can't get any numbers off of it. The belt looks to need to be a few inches longer to fit. Any idea of a part number? Thanks in advance.
  • Replies 5
  • Wip
  • sh2sh2
  • johntech
  • Captain Dunsel
It's a stretch belt
I understand that but how can you get it to stretch that far?
I normally put it on the motor pulley and cable tie it to the drive pulley and start turning the drive pulley while guiding it on till it goes into place.
This helps with putting on the belt ,but can be done without it for sure. Part number: WX05X20641
well, I would not have believed that belt would stretch that far but it did. That thing must be under a lot of tension. Thanks for the help!
