AwesomeMarioFan
Hello,
We have a Maytag Atlantis MAV9750AWW, and we have been having a problem recently with the spin cycle. During the period of time before this happened, the washer would make lots of noise during the spin cycle and would "walk" around the room sometimes because of how off balance it was. The brake would also squeak after the spin cycle was ended. Now, the washer now agitates correctly, but will no longer spin or would spin very slowly.
Upon disassembly the brake seemed to have been stuck engaged, since the pulley wheel would not disengage it when turning it counterclockwise but would agitate when being turned clockwise. When removing the brake the tub would spin freely, so we ruled out the bearings being the cause. We attempted to replace the snubber ring (old one was almost completely gone) and transmission pulley assembly in the unit.  We were unable to finish installing the transmission pulley assembly because the included washer would not fit with the e-clip no matter how much we tried to raise the transmission shaft up (using flathead screwdriver). We were able to install it without the washer but it seemed to be very tight and even forcing the cam to turn to raise up would not disengage the brake. After messing around with the transmission some more we sort of gave up since we didn't want to replace the entire transmission and didn't have the bearing removal tool for the unit to remove it.
It seems that the problem is that the brake will not disengage because the transmission is locked up? If anyone has any ideas please let me know. Also, if anyone knows where to get the special Maytag repair tools that would be great, since they don't seem to be available anymore. I have the washer's repair manual and can post it here if it would help out with repairing this problem.
- John
  • Replies 1
  • Hiroshi
  • AwesomeMarioFan
There is a white plastic cam that should track with the pulley in agitate, but should make the pulley climb and release the brake when spun in the spin direction... If the cam is stuck, silicone grease it to allow the climb. The pulley will 'pop' back out of the spin/brake release position when you stop physically turning it towards spin if it is lubed well enough- I mention the cam because I didn't see it referenced in your explanation, and it is essential to brake release for spin and brake engage for agitate.
