Shan_shan813
WFW8300SW00, Whirlpool Front Loader Washer
1st issue:   Last wash, it was not spinning or agitating, loud noises when spinning and clothes come out of the washer dripping wet
2nd issue: When washing it made a strong noise and stop working.
3rd issue: Front Door was locked and would not open
4th Issue: foreign object, I found a piece of wire after I manually opened the door
5th Issue: Code Error F24
Tasks completed:
1st task: Removed the piece of wire
2nd task: Changed the Water Pump - the old one I could not open it and it was too rusty
3rd task: Changed the Temperature Sensor as instructed to fix Error F24
4th task: Changed the CCU but it was given any error and acting crazy. Normal was 90 minutes instead of the normal 60 or so.  I returned the piece.
The machine still gives me a code error F24
Please help.....
  • Replies 1
  • PDuff
  • Shan_shan813
Was the wire found inside the inner tub?
I can see the NTC sensor on the breakdown, but I don't see a heating element.
Check the wire harness to the sensor for damage.
