Serial number CE 310 3481
The washer won't advance through the progression, it get stuck with a tub full of water, will not advance from wash to rinse, or rinse to spin on the normal wash setting, but it appears to work fine on the Permanent Press and Ultra Clean cycles.
Is your assessment that it's the timer that's bad?
There is continuity at the timer motor...
Thank you!
  • laxdef69
  • Hiroshi
  • Gnominator77
I would first check to see if your lid switch is functional. If not, the machine will just sit there when it should be draining and spinning and advancing to the next part of the cycle.Part number: 285671
Part number: 285671
It tests for open when not depressed, and continuity when pressed.
Permanent Press Cycles and Ultra Clean cycles advance fine.
Just the Regular cycle...it goes through the progression, but hangs on the spin after the rinse.
So, lid switch OK and fill valve OK.   Check for voltage at the motor when it "hangs-up" as these three speed models can have motor/speed selector issues... it may only run on the lower speed windings.
If you have no 120VAC to the motor during the failure, I would agree with the Timer as the issue.
