I've got a Miele G892 SCU Plus, and I'm getting an F06 error code:  Too few pulses at flow meter/start of water intake
what pulses? does anyone have a service manual? All i'm finding online is it could be the flowmeter board or the WPS.
Is Miele the only source for parts?
  • Replies 1
  • northeastappliance
  • AllPhase
As the unit fills, water passes through the flow meter that has a little wheel in it. Magnets are attached to that wheel. Each time the magnet passes the flow meter board it creates the "pulse". The computer is looking for a certain number of pulses per fill cycle ( I can't tell you how many because I don't know). So some things to look at are:
-the waterproof system. Is it allowing water into the dishwater or is it humming and not letting water in?
-where the wps attaches to the water supply, there is a small screen. Make sure that is not clogged/restricted.
-if it is filling with water, what is the water level in relation to the handle on the triple filter when the unit faults out?
-also take a look at the flow meter/ flow meter board(both are located in the water diverter on the side). I've seen the board move back a little bit so it was not reading correctly.
-lastly check connections and wiring.
This should get you off to a good start. Check all the above and let us know what you fine.
