runs through cycle until inmiddle of  end of cycle
both during a regular cycle and a test cycle
dishes are clean but very wet
the heater works (heats up water and at end of cycle turns on for a little)
thanks for reply
  • Replies 12
  • Joney
    8
  • johntech
  • Budget Appliance Repair
  • certified tech group 51
sorry i forgot to mention how it fails
the way it fails is it just shuts down and the clean light turns on and if you open and close the dishwasher it doesn't clear
also if you press any buttons there is no response (as if control board just locks up)
but if you reset braker it will do cycle with same issues
Cannot decipher what the problem is...Not finishing a cycle???.......
yes it doesn't finish cycle but the clean light goes on as if it is done ...
and it is locked up
and it is locked up
appliances R en
Did the dishes dry at the end of cycle
Thanks for your reply  no the the dishes didn't dry at end of cycle
How long does it run before it shuts off? Are you using rinse aid? Is heated dry turned on? For the best drying results on that dishwasher you should use rinse aid.
Per owners manual plastics will most likely need to be towel dried but glass and metal should dry and rinse aid must be used. Your dishwasher has a vent on the left side of the door that should open during the drying part of the cycle.
Heated dry is on I think they are using rinse aid ...
Ok but
As I said earlier the issue is also that the control board locks out (with clean light on) and the only way to make new cycle is to reset beaker (opening and closing the door doesn't help)
Thanks again for your time
Definitely need to replace the control for the not resetting when the door is opened after the cycle is done.
I've ran into two of these models with that exact same problem.   I did some preliminary quick checks on diodes on the board, (not with one of the diode leads removed so that is why I'm not completely sure), it appears one of the diodes that is to block voltage for the constant power to board from feeding to the door open circuit is shorted so when the door is opened it doesn't loose the 120 Vac door circuit because the main power feed for the board flows thru the shorted diode and keeps the door sense circuit powered even with door open.
Thanks for your help
