LG Front Load Washer Spin Cycle Very Loud
  • Replies 5
  • BlakeL
  • john63
  • Sean Hufstedler
  • 16345Ed
Sean Hufstedler
Sounds like a bearing to me. Look for water or rust stains running down into or onto the stator on the back of the tub. If there is you definitely have a bad bearing.
3 hours ago, BlakeL said:
Our washer has started getting real loud during the spin cycle.  It does not seem to be too unstable or bouncing around so possibly one of the bearings.  Below is a video of what it sounds like.  Any ideas of what's wrong with it so I know what to look for when opening it up?
https://drive.google.com/file/d/1lzAdwke8ZfSLRfT_xW3e_OHTZGQ4wPqmaQ/view?usp=sharing
Please always include model number.
Probably bearings but worth checking nut on back of motor for tightness.
I was able to get everything apart and it was the bearing behind the seal that was all rusted out.  I ordered both bearings and that seal but I also found a few other issues.  The main one is rust that seems to be caused by bleach leaking out of the dispenser.  I noticed a gasket that is on the back of the front control panel that is mostly gone. I did not find any place online selling this gasket.  Should I just put some silicone in there when I reassemble?
Model Number is WM1815CS
Gasket material not available (must buy Control Panel).
Yes---silicone is a good substitute.
Bleach is highly corrosive---any contact with metal will rust unless wiped immediately.
Most rusted front cover/panels---are the result of bleach splatter when attempting to fill dispenser.
Thanks, I'll go ahead and use some silicone.
