Manufacturer: Kenmore
Type of Appliance: Range
Model Number: 79046813991
The hinges on the range are bent.  Need a tech sheet to understand the hinge
Weird-- it's a good model number because it pulls up at the Sears site but I can't find any tech info on it at the Frigidaire B2B site. Hopefully someone else can help us out.
It is a hinge and roller model... so you lock the hinge when you have the door open, then remove it as you make the motion of closing the door again...
Thanks for pointing that out, Hiroshi.
That service manual was already in the Downloads section. I'll go ahead and include the link here:
The one hinge is bent.  So, it doesn't lock like it should.  I appreciate the input.  Ill check out the manual above.
  • 3 years later...
That manual doesn't look close to the slide in 79046613502
Doesn't include error codes or schematic for mine.
@Here Now Tech It is best to start your own request or new thread!
Others have and they're referred to the same file. Which doesn't have vital info. But yeah, I'll do that and see what helpful response I get.
