Model : pb975st1ss ge double oven beeping and flashing f72
Ge double oven range flashing f72 and beeping. Ovens do not work.
  • Replies 5
  • Hiroshi
  • mjorrin
It means you have a broken component in the machine. Time to start diagnosing parts... do you own a meter?
Yes, i do. Where do i start. ??
Ok, are you double sure about that failure code? F72 is not in the service manual, but GE has it listed in a generic guide as :  "F7(*) means a broken component in the unit"
I interpret that to mean that you could get F7 (and any number, in this case 2) and it implies a broken element, motor, or sensor.
First, pull the machine away from the wall and UNPLUG IT! I always meter the 240VAC outlet for 120VAC from each live prong to the ground prong. If either side is missing voltage, reset the breaker to see if it restores full 240VAC to the outlet... After that, remove the back metal cover (which may be more than one panel)on the range to expose the wiring to all the elements
When working on an oven, it is always best to test the temp. probes, also called sensors, for their Ohm's resistance. at room temp (75 degrees F)  they should read @ 1100 ohms
There will be an upper oven sensor and a lower oven sensor they will look similar to this: Part number: WB21X22134
Part number: WB21X22134   they are dead center, just beneath the broil elements in each oven. Identify the white plastic "molex"
connector that will attached to two white wires coming out of the insulation between the leads for the broil elements.
After testing the probes, look for any obvious signs of wire damage, burn marks, or anything suspicious, since most of the components we will be testing are wired from the rear... If the probes test ok, it will be time to move on to the elements...
I always go from testing cheaper, physical parts first and expensive electronics are last and only mess with the main board diagnostics if I find nothing, or to test if the error is gone after I replaced a part that failed meter testing...Your F72 code is a tricky one we must approach this way.
Edited by Hiroshi
spellings
All components tested ok.
I guess i just neet to order the main pcb???
Then you can order the PCB with a clear conscience, hopefully it is a plug and play repair from here on out!
