Arthur_Telian
If you want to contribute to the longetivity of you garbage disposal life you have to learn some garbage disposal maintenance and care tricks. Following these tricks and tips on garbage disposal maintenance your garbage disposal will last for a longer time.
Tip # 1 for Garbage disposal maintenance | Stay away for pouring used oils and greasy things in the disposal!
In order to avoid bad things for your garbage disposal maintenance you should stay away for pouring used oils and greasy things in the disposal. Those oils will solidify in the drainpipe over some period of time. Then that will cause very frustrating blockages. Instead of just pouring it in the sink, you may gather that in some container then allow it to solidify and only after that throw it into garbage can.
Tip # 2 for Garbage disposal maintenance | Stay away from grinding food wastes like fruit pits, some bones!
If you want the blades of your disposal stay sharp for a long time and avoid dulling, you should stay away from grinding food wastes like fruit pits, some bones etc. But you need to pay attention that it will okay if you grind some small bones because in fact, they can be very good for getting rid of some particles that were left in the disposal.
Tip # 3 for Garbage disposal maintenance | Do not to put potato peels in the garbage disposal!
It is essential to remember not to put potato peels in the garbage disposal. That will be a huge mistake if you do. Starchy foods like potato, corn husk, artichoke banana peel and others should never be inside you garbage disposal. The fibers that they have can cause some tangles and that will jam the thing in the end.
Tip # 4 for Garbage disposal maintenance |  Stay away from grinding coffee and egg shell in the garbage disposal!
Garbage disposal maintenanceBesides the food that was mentioned above you have to remember to stay away from grinding coffee and egg shell in the garbage disposal.
Tip # 5 for Garbage disposal maintenance | Never overfill your garbage disposal!
You should never overfill your garbage disposal whenever you use that. That will jam the thing and sometime later it will break down.
  • Replies 0
  • Arthur_Telian
