Whirlpool GU2300XTVT1 Dishwasher Detergent Door Broken Tab
moto377
Hello, the small plastic tab on the spring loaded detergent door recently broke and no longer engages with the latch.  Hence, the door is always in the open position.  A couple questions:
1. Do I have to replace the entire assembly, or is a door/cover replacement available?    I believe this the assembly: https://www.repairclinic.com/PartDetail/Whirlpool-Dishwasher-Detergent-Dispenser/WPW10605015/3023238?modelNumber=GU2300XTVT1&ss=a9b5d704515&mr=1
2. I am trying to fix the tab by bonding my own tab in place.  Is there a diagnostic mode that will allow me to actuate the latch so I can confirm if my fix works without having to wait for an entire wash cycle to complete so I can see if detergent door actually opened?  I would like to close the detergent flap and then open it via a diagnostic code, if possible.
Thank you
  • Replies 4
  • moto377
  • Hiroshi
The original dispenser assembly part #  W10224429, subs to a new number: part #  WPW10199696 , which is $68 bucks ($28 dollars cheaper than  WPW10605015)
Part number: WPW10199696   I would skip the glue, it will not be durable enough for a permanent fix... glue is never strong enough to hold up on moving parts, in my experience.
Part number: WPW10199696 You can trigger the door to open during diagnostics, but not as easily as a one-button push.
There should be a tech sheet with full instructions in a plastic envelope on the back of the kickplate under the unit.
