Bosch SHU43C02UC/22 dishwasher
Palmetto Girl
Hi, I guess this might have been covered before, but I couldn't find exactly this.
My dishwasher works fantastic! It drains well! I can check after the cycle and it's fully dry on the bottom inside.
BUT.......
If I come back an hour or so later, there is clean water in the bottom, about a half an inch.
Overnight? About an inch and a half.
So, what part do I need? I can make it drain by pressing the two buttons on the front, but it will just begin to slowly accumulate water again!
  • Palmetto Girl
  • applianceman1
applianceman1
I'm thinking that you inlet valve is leaking by.
You can try draining the washer then shutting off the supply water
 to the dishwasher.
If no water then you'll know it's the valve.
Part num. 00425458
  • 2 weeks later...
Palmetto Girl
Thank you so much!
