remunguia1
Hey guys, I'm working on a frigidaire window a/c and I'm trying to get the voltage to the display board. From the main board to display does not say on wiring diagram. No service manual either. Any suggestions?
  • Replies 10
  • remunguia1
    8
  • johntech
Posted Images
Need to post model number.
remunguia1
Yes it's FRA15mt1 it's a 15,000 btu and when I plug it in it'll beep and display lights up and then goes dead. Won't turn on.
remunguia1
Any manuals on this or what's the voltage to display? Dc or Ac?
remunguia1
Sorry it's FRA156mt112! Service manual or what voltage should come from main board to display board? What pins? Thank you!
remunguia1
Fra155mt112
remunguia1
Just now, remunguia1 said:
Fra156mt112
Posted (edited)
The wire diagram for this thing is a joke. Looks like cn1 goes from the main board to the display board. If it were mine I would confirm that you have 120vac at the main board between ry7 3 and p8. Next I would check for 5-12vdc to the display board on cn1. If I am getting stable power to the display board and it is not lighting up then I would replace the display board. If I did not have power to the display board or it quickly disappeared I would want to check the transformer connected to cn5 and cn6 but they do not give any details on the windings so I would check voltages going in and out.
IMG_0213.PNGMany someone else who has more experience on this model or access to better info will chime in.
Edited by johntech
remunguia1
Yes I have that but what voltage should the display board have from the main control board? DC?
remunguia1
Yeah I know, it's frustrating when you can't get the details. Frigidaire wont release any info unless you pay for service!
