I got the dryer disassembled and determined that the thermal fuse is blown.  I will blow out the vent piping and make sure there are no blockages.  This dryer is probably 18 years old.  What other parts should I replace while I have it open?  Belt? Rollers?  Any gaskets? I saw a suggestion to replace the gas valve coils...
Thanks in advance.  JimC
  • carp2k
  • Hiroshi
  • johntech
  • 16345Ed
Vacuum inside good and use this kit to replace wear parts.
Part number: 4392067
Blowing out the duct is not a good way to clean them.
Part number: Rle202
Part number: Rle202
remove the back metal panel and clean out the blower housing while you have the machine apart it will collect lots of pencils, buttons, and lint over the years.
