AccApp Posted December 30, 2017 Share Posted December 30, 2017 Water runs, no fill it must be the control board where does it go, then? Link to comment Share on other sites More sharing options...
AccApp Posted December 30, 2017 Author Share Posted December 30, 2017 only in heavy it must be the control board water enters still Link to comment Share on other sites More sharing options...
AccApp Posted December 30, 2017 Author Share Posted December 30, 2017 bad drain connection I show her the manual water can siphon Link to comment Share on other sites More sharing options...
AccApp Posted December 30, 2017 Author Share Posted December 30, 2017 I explain hookup the hose must not be air tight vacuum break needed Link to comment Share on other sites More sharing options...
AccApp Posted December 30, 2017 Author Share Posted December 30, 2017 Later in public I see her, does not recall from where she knows me Link to comment Share on other sites More sharing options...
AccApp Posted December 30, 2017 Author Share Posted December 30, 2017 Fixed your washer it was not the control board but siphon issue Link to comment Share on other sites More sharing options...
AccApp Posted December 30, 2017 Author Share Posted December 30, 2017 is washer running? in all cycles, properly? fixed by a gap Link to comment Share on other sites More sharing options...
AccApp Posted December 30, 2017 Author Share Posted December 30, 2017 you are most welcome she remembers her anger the truth can fix all Link to comment Share on other sites More sharing options...
Register a new accountSign in
