Yes there is always that chance.
Easy to test.
Position spray arm pointing straight at you.
Close door start wash cycle, once you hear wash cycle circulation open door.
Is spray arm in same position? Or has it moved?
Also closely inspect spray arms openings, looking for clogs and cracks.
Are you using rinse aid?
Edited by 16345Ed
  • Replies 29
  • 16345Ed
    13
  • xyourobob
    11
  • Kendell
  • Tachi
The arms are definitely spinning, we swapped out the the little biscuit soaps out for a liquid and I assume coupled with the increased water temperature she seems to be cleaning much better. Even the interior of the dishwasher seems to shine more after a wash. Thank you everyone for your input.
Glad to hear it, thanks for reporting back.
  • 2 weeks later...
Run lemishine or other dw cleaner through dw   It may takebseveral times. If cold water was used, the soap will not break down and therefore pump and spray nossles could be plugged with soap see above.
Also, make sure you are using a Jet Dry agent to allow for the water to sheen off of glasses, plates, everything but plastic
