Agoodapplianceguy
Manufacturer: Samsung
Type of Appliance: Washer
Model Number: Wf241anwxaa
Need tech manual for WF241ANWXAA
Thank you.
  • Replies 6
    4
  • Agoodapplianceguy
41 minutes ago, Agoodapplianceguy said:
Search the Files section using a truncated model number with the wildcard and you’ll find the Fast Track. For example, I used “wf241*” and two hits in the Files section pulled up.
The only thing the service manual is good for is disassembly. If that’s what you need, download  the service manual for any Samsung front loader— they’re all pretty much the same.
Agoodapplianceguy
I was searching by the full model # thank you.
What I really need is a parts break down of this I need the user interface and can't find anything online. Repair clinic Sears etc unless the model # is different and parts are interchangable.
Not interchangeable but, with Samsung and LG both, you always want to get part numbers off the original part whenever you can because they’re both pretty bad about coordinating part numbers and documents like break down diagrams. But I’ll see what I can find.
Parts manual
Agoodapplianceguy
6 hours ago, Samurai Appliance Repair Man said:
Parts manual
Thank you so much. I really appreciate the work you do here.
