Manufacturer: GE
Model Number: ZIS42NCA
Looking for manual on older style built-in GE SxS - not the ZIS420* (those are the newer ones) - must be the ZIS42N*.  It has the evaporator above the cabinet with evap fan blowing downward.  Specifically, need something that shows duct work.  The air return from the fridge side appears to be internal to the fridge wall between the fridge and freezer compartments.  Damper from freezer to fridge is mechanical-style with capillary tube, operating correctly.  Air will not transfer through, and I'm afraid the return duct has frozen up somehow.  Need a wiring diagram to check for internal heaters and a clear picture of the return duct to the freezer section.  Please feel free to transfer this to the forums, if there is no service manual, for anyone that knows this style.  Thanks in advance for your help.
  • Byrd3825
  • Lighthouse
Submitted the mini-manual
Good to go. Domo, Brother @Lighthouse!
Thanks for the quick response.
