Whirlpool Fridge wrx735sdbm00 ice maker
18 minutes ago, Lighthouse said:
The one you are working use SM 16026313
I don't seem to find SM 16026313? But that's O.K.
You've done enough for me. I owe you man.
Thank you so much for your valuable time.
Quick
If I wasn’t babysitting a dishwasher right now I would download it for you
OK I fat fingered it 16026312
Good information. You've done enough. I know you are not my tech line. But I do so appreciate it.
The manual you shared with me gives some good insight. That manual is for a 3 door box and mine is a 4 door.  It did give me a better idea as to the air flow. But one of the things I noted manual 16026312 gives a thermistor reading at 36 degrees to be 29,198 ohms while the tech sheet shows 7,964 ohms? W.P. has done us no favors.
Not tech line but here to help anyone anyway I can. I learn & help myself when I help others
  • Like 3
I notice too that the "Water Flow Diagram" on pg. 21 of the Service Manual  only shows one dual water valve, no isolation valve , while the Tech Sheet that ServiceMatters shows for this unit ( W10814246A ) clearly shows the isolation valve and diode pack on both the schematic and wiring diagram. Notably, the 2 parts breakdowns (!?!) that ServiceMatters shows for this one don't show the isolation valve or diode pack.
No favors, indeed.
I do like those water and airflow diagrams in the Service Manual. I wish they would make those for all units.
