Hi folks.
I have a nice clean secondhand Bosch WFL1662 front-loading washing machine.
During spin, and occasionally during wash rotation, there is a knocking noise inside.
I have removed the top of the machine and rocked the drum front-to-back, first on the right and then on the left side. There is knock/clack always on the right side, rarely on the left. It does not vary depending on rotation of the inner drum.
Also, when rotating the drum slowly, there is a squeak.
Otherwise, it's all working fine.
I have uploaded three videos describing this to the WeTransfer sharing site, links below.
I would appreciate suggestions on probable causes and recommended repairs. It will most likley be done by myself, as my budget is currently being spent on new, non-leaking gas pipes :D
Stuart
Test Rock Drum:
https://we.tl/t-0n1MCLakDo
Spin Rattle:
https://we.tl/t-ImYcSK5K1a
Squeak:
https://we.tl/t-iP4h7eotwo
  • Replies 4
  • EssCee
    5
Update:
I've just done the quick test shown in the video 'The Tell-Tale Banging Noise of a Broken Drum Support Spider in a Samsung Front-Load Washer' (different brand, but I figure the same concept applies). The drum does not rattle loose inside the tub, I can feel the tub and drum moving as one on the springs.
Oops. Quoted the wrong video. It was this one: 'Secret Samurai Technique For Checking The Drum Bearings In A Front Load Washer'
All suggestions welcome...
It's quiet in here...
I'd appreciate any assistance on this - including whether I'm actually asking in the right place...
