Fisher Paykel DD605 Experts Needed
I have a problem with a FP DD605. The lower unit isn't draining. Motor Housing and Hoses are clear. Motor Rotor got loud, and eventually lost the plastic coating, scarring the inside of the housing. I bought a new one, the updated P/N, and while the rotor fits, it is different. The motor spins are high speed. The bottom of the motor is flat, whereas the original ones were "ramped". See pictures. Motor runs, but doesn't pull water out of the tub.
Heating elements have been replaced several years back.
No error codes, motor has been tested using the Hardware Output method. (P2)
So my question, could the scarring of the motor housing, while minimal (see pictures) disrupt the new motor pumping action or is there something else that I am missing? Are the new motor housings made different?
Tomorrow I will swap motors again, between the tubs and see if it makes a difference.
  • Replies 7
  • roryrhodes
    4
  • J5*
  • Luke Miller
The new pump is for a 603 not a 605
thats why you have issues
603pump
524185p
605 pump
524285p
you will notice the plastic ramp difference
on the 603 it was part of the motor housing and would get damaged so on 605 they moved it to be part of the rotor
Which btw there is prob a blockage in the drain hose , common where the drain hose exits the cabinet as there’s is a sharp bend
often  plastic from the  plate racks that snaps off
pull the hose back through the cabinet and straighten it and blow from the end back and get the blockage to blow out
J5* Thanks.
The new pump was marked as a 524285P. Probably a consumer switcheroo and return - send back. I'll order direct from Paykel.
I blew out the hoses, didn't see anything come out, I may need to completley pull. I suspected plastic from the damaged rotor casing but didn't see it come out of thehose or housing. I'll take another look.
There is a sandy looking darker grit in the tub. No much, but it's there. You can see it in this picture.
https://www.dropbox.com/s/qgq3odnkyi1elda/IMG_0023.jpeg?dl=0
I appreciate the help. Very simple system, works well when it works.
The grit is generally detergent residue , you see it a lot if people use the eco cycles as it’s not hot enough
when the rotor delaminates badly like that and damages the housing it can cut a hole though and you get water leaks
any time you see one of these units it’s prudent to check the rotors for any damage of the impeller and delamination of the plastic
All is fixed and well. You were correct, the hose had chips of plastic in it, presumably at the bend. The correct part from FP was correct. Thank you again for your help. Rory
  • 3 years later...
thanks!
