FEF375GCA Not heating - Anywhere
Frigidaire Stove model Fef375gca isn't working. The burner tops aren't turning on and neither element inside is working. The breaker is on, the display reads what it should read. Preheat light goes on, but never heats, hot burner light goes on but no burner heat.
is this a control board issue despite the control board giving a proper display?
thank you
  • Replies 4
  • xman1x
  • Jedi Appliance Guy
  • 16345Ed
Could it be that there's some sort of electrical problem? Maybe it's getting the 120 it needs for the display to work but not the 240 needed for heating...
Could very well be...
Flip breaker completely off then back on.
I did. Didn't work
You can visually inspect the main terminal where the power cord connects to see if 1 leg has burned open from a loose connection. To go any further you're going to need a meter.
