My GE washer, WHSE5240D1WW, will fill normally and run through cycles normally But only on small setting. If on anything larger, it'll work until it hits the rinse cycle and then I'll dispense very little and will stop altogether after what looks like a gallon of water (less than the small setting's amount of water). Thoughts?
Good Water pressure getting to washer  ??
Clogged water inlet valve more than likely.
Thank you. I'll check.
Let us know...
Replaced the inlet valve and that part is all good... But now it won't spin.
Drains?
Yes. Still drains
There is a service bulletin that may pertain. Need to remove pressure hose at tub and clear port with small drill bit.
  • Like 2
yeah there is a bulletin out on this as ED mentioned.  You need to clear the flash chamber on the lower right rear of the tub at the end of the water pressure hose line.   pull up the error code history before you get to involved with other stuff.  it may lead you to the problem area quicker.
Thank you.  Are we talking about the no spin issue now or still the filling issue because I was about to resolve the no fill issue with a new inlet valve but now it won't spin
not sure why you needed to change the valve. the valve can be ohm checked or live checked during any of the fill processes to check that.  since you have already replaced that valve I was assuming you were talking about the spin issue. Pull up the error code history from the diagnostic sheet in the console. I would start there first after clearing the flash chamber as Ed mentioned if that does not fix the spin issue you are having at the moment now.  good luck ok. i'm going to bed . It's late and i'm Tired   :lol:
Attempted to clear the flash chamber using the drill bit as suggested but nothing really seemed clogged. Then I went into diagnostic mode. Getting an error code for the push button... Otherwise, works on all cycles during diagnostic, except spin.
