Kenmore Washing Machine 110.28822790 Timer Knob turns/dial guard timer issue
soccerfreak
I can push in and turn the timer knob but it won't advance the dial and guard timer to select the cycle.  Which means it won't turn on.  Any help would be appreciated.
  • Budget Appliance Repair
  • soccerfreak
  • MrApplianceMatt
WP3949428 is likely the part that has failed. If you can find both this and the knob you can probably clear up your issue, but the knob is no longer manufactured and I can't find a replacement number. Can you rotate the timer dial by hand and select a cycle?
Edited by MrApplianceMatt
No, the problem is the timer - if you are resourceful and have some mechanical ability, you can take the timer apart and replace the shear pin that has broken or fallen out.
Part number: WP3950200
Or you can go the cheap route and push the timer to the off position and hopefully you can get a hold of the nub on the back side of the timer with pliers to hold the shaft from turning while unscrewing the timer knob.
Once you have the timer knob off you can remove the timer dial that MrApplianceMatt referred to in the above post and remove the clear protector dial off the main white part and reinstall without the clear shield.   Reinstall timer knob.
Know you can turn the washer on/off by pushing/pulling the timer knob and only turn the timer dial by hand when timer is off - you can set the timer but directly turning the timer dial instead of turning the knob to set the cycle.
