      5
      All Appliantology tech members are invited to join in this workshop on all things Appliantological.
      We have a special session planned for this one. Instead of the usual Show 'n Tell on a technical topic, we're going to post tech sheets in the comments to this Calendar Event (scroll down to see what's posted so far) and ask specific questions that can only be answered by reading the tech sheet. If you at least try to answer the questions beforehand, you'll get a lot more out of it. The tech sheet and the questions are posted in the comments section below.
      Your mission, if you should choose to accept it, is to check out the questions for each one and try to answer them ahead of time. Then come to the Dojo to see how well you did!
GE/Mabe Washer Tech Sheet & wirinig. Oh Canada
Not_Another_Username
Manufacturer: Mabe Canada INC
Type of Appliance: Washer
Model Number: GVSR1060H3WW
First request virgin, hope I never missed in search and apologies if I did. Have found everything else in the past. Thank you if you can find it.
Link to comment
Being your in Canada for this GE washer the way I got to the mini Manual or tech sheet if you will is I went to https://www.partselect.com/Models/GVSR1060H3WW/
And then click on controls for you Model and saw mini manual as there own part number than click on that.That bought up the GE Mini Manual number than search for it here! Hope that makes since!
Link to comment
Very much apprciated. Thanks for info and quick reply!
Link to comment
