Maytag gemini mgr6775bds trouble shooting mode
I've a Maytag gemini mgr6775bds that will not light the upper oven despite a new igniter.
How do I enter the trouble shooting mode to stop chasing putting in unneeded new parts? I can't find instructions on how to enter it for the trouble codes.
TIA!
Is the igniter glowing? Do you have voltage to the igniter? Typically these units will not store error codes but will only display them when the condition for an error is present. You need to verify voltage to the igniter and what kind of amperage the igniter is pulling. If you have voltage to the igniter and it's glowing and you can measure the amperage and that amperage is sufficient to open the safety valve (3.2-3.7 amps typically) then you have a fuel delivery problem.
No voltage/not glowing.
Love Guinness as well!
Thanks; will try tonight to dig a bit more into this.
Igniter does work for broil but not bake. Might this mean something?
Trace the wires from each igniter back and look for a double line break relay. I've seen these go bad before in this way in their electric counterparts.
