Kenmore Washer 11020022013 starts spinning then quits
KENMORE washer starts to spin then stops, lid light flashing after cancel.
Diagnostic code says speed sensor issue. Where's the speed sensor located? On the shifter?
The sensors are in the shift actuator. There is also a shutter ring on the transmission, you can see it when you remove actuator.
