Kenmore Range 790.92703011: Need a new Large Element Switch
I just replaced my oven with a used Kenmore 790.92703011, and in my haste to move it into the house, I sheared the shaft off of the large front element switch.  I disassembled the front panel and attempted to locate a replacement to order.  I was directed to part AP5325508, which can be found here amongst other places.  The issue I have is that this part does not quite match the part I have.
Here is a picture of the replacement part:
And here is the part I currently have with the differences:
The circled portion shows where the wiring is doubled up on a single post with a connector between the two wires.
This picture shows 2 unpopulated posts that are populated on the replacement.
I am fairly sure the replacement part will work, but I figured I would run it by you guys before I pulled the trigger.
  • Replies 0
  • Chaosmos
