Manufacturer: General Electric
Type of Appliance: Electric Range
Model Number: JB690SFSS
I need the tech sheet and manual for GE Range Model#JB690SFSS
  • Replies 9
  • brorobj
    5
  • Son of Samurai
  • Vance R
Are you sure that model number is correct? It's not pulling anything up for me at Repair Clinic.
i understand. When I checked the model number on Repair Clinic I got nothing but got results on Appliance Parts Pro. Still not convinced I went to GE website and found it there. It is a valid number but have no idea why the issue exists. Appliance Parts Pro gives some alternate numbers. I'll try using one of them.
Based on the similar model numbers that Appliance Parts Pros gives, it looks like there should be a number as the third to last character, between the F and the S.
I tried that and got nothing. I did a model cross reference and found a Kenmore that uses the same RTD. I need the tech data on that sensor. Diagnostically I'm at the point where it's either the RTD or EOC. Not wanting to throw parts at this range needlessly
Chasing down this RTD the only two points of reference I can find are room temp and clean temp. Is there any place I can find additional tech info on RTD #WB21X22134?
There is a generic chart here that is close:
Little late, uploaded tech sheet pending approval:
Thank You!
Approved -- thanks, Vance!
