Maytag MAH5500BWW Neptune washer eats bearings
Follow up on my problem posted above... After the third tear down, I seen my mistake, the seal was installed wrong side in. I flipped it and everything went back smooth. Thanks to everyone involved in this forum group, which helped me start looking at things better.
Could it be a washer/spacer that has eluded your reassembly? Try with out the belt I assume by your statement. Therefore it’s something to do with the way the seal is installed, wrong part, or left something out, or some sediment has taken up a space that was previously unoccupied? Or maybe the bolt is stripped or the bolt hole had a place to stop but now is going in too far?
OR
something I have not thought of
please write back we’d like to know what you find
  • 11 months later...
Years too late for this one but I would have replaced the spinner support and used the correct bolt and washer. Im fixing to do mine not because it is making noise but because it is the 10th year since my last rebuild and the 20th year for the machine since I bought it new and I want to use it 10 more years. If I live that long I will be 80 and someone else can do the laundry then.. LOL
