stuck in GE side by side purgatory.. Please Someone Help Me.
TahlequahTony
working on a GE side by side refrigerator, model # GSHL5KGXCCLS. in my last post, i had learned that i had been sold an incompatible control board. so i bought another control board.. but instead of sending me out a WR55X10942 as pictured. they sent me out a 200D6221G009. it does turn on the compressor and the compressor seems to be staying on ,but still after 12 hours, not cooling at all.. any ideas?. . is the board compatible? if so, am i looking at a bad compressor? is it posable that this board has the compressor going backwards ? i just dont understand what it might be. the temp sensors seem to be reading right, i"ve cleaned the coils, the fans are working, the unit is completely defrosted, the compressor relay clicks once and turns on.. its like its stuck in defrost mode, but the compressor is running.. any help would be greatly appreciated. before i start using it as target practice.
If the compressor is running there should be some kind of cooling.  Looking like a sealed system issue - leak, restriction or inefficient compressor.
