Washer/dryer GLGH1642FS5 (seems the same as Frigidare front-loader) various symptoms leadind to dead washer
The current status is:
  • Dryer works fine
  • Washer light comes on when activated (i.e. pull the knob out)
  • Washer does not
    • Fill with water
    • Rotate
    • Drain (based on sound)
I'm looking for information to help me find the pump (ic) board; check the fuse; test the pump
I don't know if I have multiple failures (perhaps caused by the impact when the spring broke): the speed controller, the pump, etc.
Please advise
History, oldest to most recent
  1. Washer ande dryer worked fine
  2. Loud noise and washer stopped rotating in any mode
  3. Diagnosed a broken support spring
  4. Received and installed a replacement spring (and a replacement electric washer moter, belt, and schocks ready to return for a refund)
  5. Washer fills but does not spin. During what would be wash cycles, the drum rotates rarely and slowly. Drain pump makes a lot of noise
  6. Remove drain hose (drump to pump) and empty coin trap (it was full)
  7. Reinstall drain hose
  8. Washer fills but does not spin. During what would be wash cycles, the drum rotates rarely and slowly. Drain pump makes a lot of noise
  9. Attempt to clear hose from pump to exit pipe
  • RichardHaven
  • 16345Ed
Remove pump and inspect impeller for debris.
if pump is making noise it’s getting power.
I was making noise, now nothing happens
Did I burn out the pump, or might a fuse have blow? Where should I look on the conotrol harness?
