Good evening, this is my first post ever. I am trying to locate the manual and schematic for a washing machine which is occasionally leaking (enough water to soak 1 or 2 paper towels) at the front left leg. I initially accused my cat of peeing there but she swears that this is not the case.  If you could help us locate the evidence to exonerate her, she would be much obliged. Thank you. 🐾
  • Replies 1
  • ABA Tech
  • UntMike
Posted Images
Easiest way to figure this out is to remove the cabinet and run it with that off. You’ll need to jumper the lid switch with an insulated wire as well.
 This video shows how to remove the cabinet.
