Fault Code - Control Panel
CTChampion
I have a Fedders window air conditioner model A6D24E7B.  Sometime during the night it powered off and shows "E3" in the display.  I can unplug/replug the unit and attempt to turn it on, but it only runs for a couple of seconds before powering off again.
I called Fedders Customer Service and they told me the code referred to the control panel.  My question is, can I replace the control panel, or would it be more beneficial to just get another unit?  I didn't buy this unit, so I don't think it would still be under warranty.
Can anyone advise me on what I should do?
Thanks!
  • 2 weeks later...
Guest ahammer48
Hello
Did tech support say anything else? Thats it? Replace the control panel. If thats their answer then I guess thats what has to B done.
Now its up to U. I would compare the cost of a new panel to the cost of a new unit. Also do you feel comfortable changing out the panel or would U need to call in someone.
Basically U need to decide if the unit is worth the time-trouble-cost- of repair compared to replacement.
Hope this helps:)
 1-800-269-2609 call for control panel quote
