Thermador gas oven. Oven will ignite but gas turns off after 30-90 seconds - lights and fan all stay on but obviously no heat - if I turn off and back on, it ignites but again turns off after a while. Broiler works fine. Thoughts? Tech said new control board and would cost me $1500!?!
  • drewnyc
  • THRAMICH
Posted Images
It very well could be the control board, but I would need a lot more information to help you. What is the model and serial number? What level of diagnosis have you attempted so far? Does the broiler function? Have you tested the output relay of the control board for voltage output under load? Have you tested the temperature thermistor for proper range?
Broiler still works. Don’t know how to test board voltages.
