Manufacturer: Electrolux
Type of Appliance: Microwave
Model Number: E30MO75HPSB
Hi Techs,
The above microwave had a blown thermal fuse. The tech sheet is missing. The unit had no power to the control board. On the parts look up the fuse was number 5 and part number is 5304451403. This fuse does not look the same as the original but it is the part number called out on parts websites. I did not determine why the fuse blew. I put a temporary fuse in and ran the unit and had no issues heating a couple of cups of water. The new fuse was installed. I have a call back that the microwave made some popping noises, smelled like something was burning and it was making a ticking noise. The homeowner turned of the circuit breaker. So I have to go back and see what else has now failed on the unit. Any ideas and a manual would be helpful. Thanks,
Tim
  • Replies 5
  • marshall450
    4
  • Son of Samurai
  • Captain Dunsel
Uploading wiring diagram thats in the last page of parts list and service manual waiting on approval:
 I had found the wire diagram. Looking forward to getting the service manual. Really appreciate it.
The microwave has been repaired. The monitor switch failed and it fried wiring. Replaced micro switches and wiring. All is good now.
Thanks, Captain!
Thank you Captain.
