Manufacturer: Bosch
Type of Appliance: 24" Condensing Dryer
Model Number: WTG86400UC/07
Can Someone please help me with the documentation I need for this one? My customer is reporting "DR" on the display and I can't find that mentioned in any of the documents I've found in the downloads section. The thing is, I'm not sure I'm looking at the right documents. Will somebody set me up with the right document or documents? Thanks!
Thanks @Captain Dunsel!
If you're referring me to the user manual, then I take it then that there's nothing helpful to a technician, like a mode where I can run the pump to see what's going on.
Do you know of any tech sheets , service manuals, or other Bosch secrets that apply to this model?
@vee8power looks like you downloaded the only one on site.
This one:
And it looks like you download this one to!
Maybe @Son of Samurai can help here!
  • Thanks 1
Uses this manual:
This schematic:
  • Thanks 1
Thank you both so much! I really get uptight when I have to work on these.
  • 5 months later...
This one is back!
It seems like there may be a docment titled "Test Program". The term test program appears 35 times in the service manual but in none of those instances does it say how to enter this mysterious program. I'm sure it's just me not seeing it. Is there another document I need to diagnose this machine?
That would be the service program doc in this bundle that Dunsel posted:
  • Thanks 1
