It's a one-year-old refrigerator, it's not cooling enough, there was an error code CL E, per these codes show a leak in the evaporator coil. I set the refrigerator temperature at 42 & freezer at 5, now no error code but the compressor is shutting off & restarts after some time. There is no freezing in the freezer compartment. I open the panel over the control board LED was blinking 6 times and paused and repeat the same pattern again and again and the compressor shuts off and start again. I google and found multiple reasons the compressor is too hot, bad capacitor, bad PCB, Restriction & Bad compressor.
There is no restriction as the condenser is neat and clean, and the suction pressure is 7 psi (600A refrigerant) I think no restrictions in lines, and there is no capacitor. The compressor is taking 2.2 amps alone. Please help me to take the right troubleshooting.
Thanks.
  • Replies 1
  • Vance R
  • Manjeet
Without the model number this information is generic.
6 blinks - high ambient temp, condenser fan stopped, high side restricted, damage compressor.
r600a suction pressure should be 15" of vacuum.
lowside leak - with the lowside pressure at 7 psi and no cooling there are probably non-condensables in the system.
