Fridgair gas range Model# FFHF3047LSF Serial #VF21461299. Oven & Broiler Not Heating.
Go to solution Solved by Vance R,
Like the title says i have a fridgair gas range that will not heat up. no oven operation no broiler operation. all you get is one "click" from the control panel. stove top works fine. any thing i should look for. by the way last service tech that came out for this problem said it just needed to be reset, what ever that means and he took the wiring diagram with him when he left.
You have model number. Could be door switch, relay on board, safety valve,or wiring problem to name a few. Could be regulator got bumped when cleaning, but I think that would cause the burners to not work also.
it is a FFGF3047LSF. I fat fingered it. i will check that out. if there is no voltage at that wire, does that mean bad board?
There is a 6 pin connector on the main board, check for 120 vac  at pin 4 to pin 6 when trying to bake. If 120 is present when trying to bake need to know the current draw.
  • 5 months later...
Sorry for abandoning this post for awhile. There is no Voltage when testing pin 4 to pin 6 When turning on bake or broil.
where should i go from here?
Check for a thermofuse in the back of the range. If it has one and you get 120 volts on bake mode activated it means you have a broken thermofuse/cut out. Check cooling fan operation if it's bad.
On 5/14/2023 at 9:55 PM, JRUTH said:
Don't see A thremofuse and no cooling fan on this model
since i dont have the wiring diagram my only thoughts are if i have power going into the control panel, clock and timer work, and no power @ pin 4 to 6 then the control panel is not sending power to the yellow wire and the control panel would be bad , Correct?
  • Solution
Here is picture to help.  Pin 4 is neutral for the board. Since you can program the board the incoming line voltage 120 vac should be ok on pin 5. Pin 6 is the out going voltage to the gas valve circuit. Since there is no voltage at pin 6 to pin 4 there is a board issue.  There is a problem with the board. If you feel comfortable take the board out and look at the solder joints on the back. Could be a simple loose solder connection.  If there are no loose solder connections the power relay maybe not working.  If you don't want to do board level repairs just replace the board.
Vance R, You were spot on with the broken solder joint on the starter relay. it took me longer to dig out my soldering station then it did to fix it saved saved me the trouble and money on the parts . thanks much.
