    258
    843
    558,616
How to Identify Unfamiliar Parts in Schematics
Take a look at the cooktop schematic below.
I don't know about you, but "tranformator" isn't a familiar term to me. it certainly sounds like a transformer, but why would a transformer be necessary in a 240 VAC cooktop element circuit?
The best thing to do here is to look up the part numbers for the "transformator" as well as other key components, such as those cooktop switches that the transformator is supplying power to. Then we can use a parts site to look at physical pictures of the parts.
If you grab the part number for the transformator and plug it into repair clinic, you will see that it does have a transformer on it. But looking closely at that picture, you'll see a couple of other things. For example, you'll see two capacitors and four diodes. The diodes and the capacitors form a rectifier circuit.
So what do you have going on with this transformer or "transformator" is a transformer that is producing several secondary voltages, some of which are being rectified and filtered into a DC voltage which is then used by the surface switches.
Why would the surface switches need DC voltage? Let's look them up in the same way! You will see this that this isn't a typical infinite switch. This is an electronically controlled infinite switch which includes a built-in LED display -- hence the need for the DC voltages.
And just like that, with a couple of quick parts look-ups, we've identified an unfamiliar component and made sense of a strange-looking circuit. All in a day's work for an Appliantologist!
Want to step up your appliance repair skills to the next level? Get in on the action here at the Appliantology forums by becoming a premium tech member today.
  • Like 7
  • Thanks 1
6 Comments
Chashb
I recall reading in a scientific journal somewhere that with a transformator,  one can make a flux capacitor open a time warp without the need for traveling at 88 mph.  lol
Charlie
  • Like 6
  • Haha 1
darren412
It seems to me that this is just a mistake on the schematic or if it is spliced in this way It wouldnt Matter really as long  the dcV is  the same at the transformers P5  Pins 2,3  ?    I noticed that the right rear switch's P5  Pin 2 wire going  to the transformers P3  Pin3 connection.   The other 3 switches P5  Pin 2 wires all go to The tranformers P3  Pin 2 connection.   Is this why that flux capacitor can use a lower MPH ??    :kopkrab:
  • Haha 1
Son of Samurai
Very good spot, @darren412! I think you're right -- that has to be an error in the schematic. I can't think of a reason why they would actually wire it like that. Here's what we're talking about for anyone who missed it:
davidg
It is a German word for a transformer.  We had better get better at using our search engine to translate , which makes the case for a universal language for electronics; like maybe English since we hold the most patents in that category.
If the FAA can convince the world to use English as the air traffic control communication default required language then we ought to be able to demand English for all.  Is the Empire still intact? Up the river Conrad!
vee8power
Don't they usually call that a DC power supply? That would be helpful.
If a tech had a functional understanding of components, then the name and labels manufacturers put on them are irrelevant. A manufacturer could call a transformer a “ham sandwich” but if a tech understands how that component is supposed to function in a circuit, they won’t get headfaked.
Focusing on labels misleads us into thinking that all the manufacturers are doing something unique and different. In fact, they are not. All the technology in appliances is standard, off-the-shelf stuff, they just use different names for the same technology.
Focus on function not labels. This is how we teach in the Core Appliance Repair course at Master Samurai Tech.
