    235
    795
    541,417
How do Surge Protectors Work?
Son of Samurai
I've seen a few guys around the forums ask the same question: are surge protectors (also called surge suppressors) safe to use on refrigerators?
Best I can figure, this question comes from folks mixing up surge protectors with AFCIs and GFCIs (you can click here to read about how those devices work). But it speaks to a general ignorance of how surge protectors work. Well, why don't we fix that?
The reason surge protectors exist is to block voltage spikes -- those are large spikes in the supply voltage that last a few nanoseconds. Lightning strikes are one of many causes of these spikes. Despite how short these spikes last, they can still cause significant damage to electrical devices, especially ones containing electronics.
There are a few different kinds of surge protectors, but we'll focus on the simplest and by far the most common kind: Metal-Oxide Varistor (MOV) surge protectors. These devices are so simple, in fact, that you can get a sense of how they work based on a picture like this:
There's very little going on here, and the only components that might be new to some techs are the varistors. So what's a varistor?
It's not too hard to wrap your head around these, either. A varistor is a component whose resistance changes depending on the amount of voltage applied to it. In the specific case of MOVs, the resistance is very high, but lowers the more voltage is applied. This is why they're called varistors -- it comes from "varying resistors". Here's what one looks like:
You might be getting an idea of how MOV surge protectors work now. With normal voltage applied to the row of MOVs connecting line and ground, those MOVs will be open. No current will flow through them. But if the voltage rises above a certain amount, the resistance of the varistors will drop, and all the current will get shorted to ground rather than continuing through the circuit. The typical spec for this in America is 330 volts. Above that amount, the varistors' resistance will be low enough to short to ground.
Now that we have an idea of how surge protectors work, you can probably see why they're perfectly safe to use with refrigerators. In fact, it's a very good idea to use a surge protector with refrigerators (and most appliances, really), especially as they become more and more computerized. Whereas AFCIs and GFCIs can sometimes nuisance trip on refrigerators, surge protectors are only concerned with the supply voltage, and so you won't see the same thing with them.
Want to learn more about the technology used in appliances and how it factors into your troubleshooting? Click here to check out the Core appliance repair training course at the Master Samurai Tech Academy.
  • Like 8
  • Thanks 1
2 Comments
Rhubarb Tau
Posted (edited)
Why do they only have MOVs to Ground on L1, not on neutral to GND? Couldn't a spike from the outside world com in through the neutral leg?
edit - I forgot Neutral and Gnd are bonded in the panel, nevermind.
Edited by Rhubarb Tau
Ghost
MOV from L1 and L2 to Ground will be good to protect electronics.  In a 220v appliance, the electronics only uses either L1 or L2.  But your first thought was correct.  Even though the Neutral and Ground are bonded at the panel, they have different jobs to do and are not the same.
Spotting blown MOV's is usually easy and many have a temperature fuse taped to them.  Many people do not know that MOV's can slowly degrade over time depending upon the number of voltage spikes they endure.  So, older equipment may have little or no protection even though the MOV's aren't blown up or burned.
Ghost
