Implicit and Explicit Specs in Troubleshooting
Specs are essential for troubleshooting. After all, to test a hypothesis, you need to make electrical tests, and to make electrical tests, you need to know what your expected readings are. However, manufacturers don't always give you everything written out. What do you do if you need to make an amp measurement, but the manufacturer only gives you watts? That's exactly the question we're going to answer in this excerpt from one of our many in-depth technical webinar recordings.
Want to watch the full webinar recording? Click below -- viewable only by premium tech members.
2
